Monitor TPX storage usage not using D STOR and D STORXA displays from TPXOPER
Article ID: 27220
Updated On: 10-02-2024
TPX - Session Management
How can I monitor TPX storage usage without manually doing D STOR and D STORXA displays from the TPXOPER session?
TPX® Session Management for z/OS
D STOR/STORXA via OPENGATE
-------------------------- Instructions to setup an OPENGATE user to monitor TPX storage constantly. The displays from TPXOPER session will be printed into TPXlog.
The interval can be set in the ACL/E program 'DSTORAGE'.
  1. Definitions in ACT
    In TPXDEMO ACT entry define OPENGATE user 'STORAGE'
                       TPX Application Characteristics Detail Panel
        Panelid  - TEN0094
      Command  ===>                                              Userid   -
        Termid   -
         Application Characteristics Table: EUNET                Date     - 03/09/03
         Applid:    TPXDEMO            * Substring:              Time     - 03:48:10
       * Sessionid:             * Label:     TPX Dummy Session
     TPX options:
     * Start ACL prior to CLSDST PASS:   N    * Outbound compression:     Y
     * Suspend background application:   N      Inbound compression:      N
     * Enforce CD protocol:              N    * Outbound stripping:       N
     * Inform user of CD protocol error: N      OPENGATE Control User:    STORAGE
     * Auto restart:                     N    * Maximum sessions:         00000
     * Inquire on application status:    N    * Mode entry override:      ________
       End-to-End option:                BB   * Timeout Minutes:          ______
     * Ignore appl output for timeout:   N    * Signal session switch:    ________
     * Disallow VIEWing on this appl:    N    * Pass Ticket prof name:    TPXDEMO
       Readbuf Technique:                N    * TPX enhanced sec:         N
       Screen even if readbuf technique: N    * Generate Pass Ticket:     N
     * Can be dynamically updated using Reload even if application is not quiesced
     PF1=Help  PF3=End  PF4=Return   PF7=Prev Page  Pf8=Next Page    "CANCEL" cancel
  2. Define a static TPX user with userid 'STORAGE'
    Make sure that this user:
    - has Security system = 'NONE'
    - has no timeout values either in user definitions nor in session definitions
    - is authorized for the TPXOPER DISPLAY command (This is based upon the assigned Operator Cmd Cls.)
    Define 2 sessions with Start at signon = 'Y' for this user:
    - a session to TPXDEMO
    - a session to TPXOPER with startup ACL/E = 'DSTORAGE'
                       TPX Userid Maintenance Detail Panel
        Panelid  - TEN0123
        Termid   -
     Userid:   STORAGE                                           Date     - 03/09/03
     UserName:                                                   Time     - 03:27:33
                                      Profile defaults    System defaults
     Command character:   _           _                   /
     Command key:         _______     _______             PF12
     Jump key:            _____       _____               NONE
     Menu key:            _____       _____               NONE
     Print key:           _____       _____               NONE
     Group name:          TPXGROUP
       Command class:     _           _                   P
       Operator Cmd Cls:  _           _                   P
       Update class:      _           _                   P
     Stage 1 timeout:     000000      ______              65535
     Stage 1 option:      __          __                  F
     Stage 2 timeout:     ______      ______              0
     Stage 2 option:      __          __
     PF1=Help    PF3=End    PF4=Return   PF8=Next Page       "CANCEL" cancel
        Panelid  - TEN0125
        Termid   -
     UserName:                                                   Time     - 03:28:14
     ACCESS:              ______      ______              MULTIPLE
     Language:            __          __                  EN
     Security system:     ____        ____                NONE
     Inactivate on:       _           _        (F=Signoff, K=Logoff)
     Maximum sessions:    ____        ____                0
     Default printer:     ________    ________
     ACB mask default:    ________    ________    ---------------------------
     Propagate ACB:       _           _          |   Static user:       Y
     Display menu:        _           _           ---------------------------
     Transfer option:     NONE        ____       |   Suspend user:      N
     Affinity applid:     ________    ________   |   Force new pswd:    N
     Pass Ticket User:    _           _
     PF1=Help    PF3=End    PF4=Return   PF7=Prev PF8=Next   "CANCEL" cancel
                       TPX Userid Maintenance Table Entry List
        Panelid  - TEN0122
        Termid   -
     Userid: STORAGE                Profile         System       Date     - 03/09/03
                                    Defaults        Defaults     Time     - 03:28:55
                          Applid      Profile     Sesskey   Profile  Menu    Profile
       Session            Override    Applid      Override  Sesskey  Order   Order
       TPXDEMO            TPXDEMO     ________    PF __     PF __     ___     ___
       TPXOPER            TPXOPER     ________    PF __     PF __     ___     ___
     ******************************** BOTTOM OF DATA *******************************
        Panelid  - TEN0124
        Termid   -
     Userid:   STORAGE            Session:  TPXDEMO              Date     - 03/09/03
        Time     - 03:29:38
                                    Profile       Application    System
                                    Defaults      Defaults       Defaults
     Applid:          TPXDEMO       ________
     ACCESS=PASS:     _             _                            MULTIPLE
     Timeout min.:    ______        ______        ______         999999
     Modent name:     ________      ________      ________
     Sesskey:         PF __         __            __
     Start at signon: Y             _
     Startup ACL:     ________      ________      ________
     ACL Userid:      ________      ________
     ACL Password:    ________      ________
     Term ACL:        ________      ________      ________
     ACB Mask:        ________      ________
     KeepACB:         _             _             N
     Invisible:       _             _
     OV/MVS ACI:      _             _
        Panelid  - TEN0124
        Termid   -
     Userid:   STORAGE            Session:  TPXOPER              Date     - 03/09/03
        Time     - 03:30:13
     Applid:          TPXOPER       ________
     Startup ACL:     DSTORAGE      ________      ________
     KeepACB:         _             _             N
     Invisible:       _             _
     OV/MVS ACI:      _             _
  3. Store following two ACL/E programs into ACLLIB
    Store this one with name : 'STORAGE'
    *  OPENGATE CONTROL ACL/E
            OPTION    TIME,OFF
            OPTION    TERM,OFF
            OPTION    FLOW,OFF
            OPTION    MAXI,0
            STOP
    Store this one with name : 'DSTORAGE'
    *  OPENGATE'S USER STARTUP ACL/E FOR TPXOPER SESSION
            OPTION    TIME,OFF
            OPTION    TERM,OFF
            OPTION    FLOW,OFF
            OPTION    MAXI,0
            WINP
    LOOP    NOP
            SEARCH    '==>'
            BRANCH    EQ,KEYIN
            WAIT      5
            BRANCH    ANY,LOOP
    KEYIN   NOP
            KEY       'D U,SUMM'
            ENTER
            WAIT      5
            COMMAND   'P TPXOPER LOG'
            WAIT      5
            KEY       'D STOR'
            ENTER
            WAIT      5
            WAIT      5
            KEY       'D STORXA'
            ENTER
            WAIT      5
    * HERE YOU SET THE INTERVAL BETWEEN THE SCREENCOPIES
           WAIT      1800              * WAIT HALF A HOUR
            BRANCH    ANY,KEYIN
            STOP
  4. restart TPX
Attention:
The OPENGATE entry in TPXDEMO ACT, the OPENGATE userid and the OPENGATE control ACL/E must have the same name ( here 'STORAGE' ) !!!
