Symantec Protection Engine (SPE) daemon (symcscan) is not getting started after installation of SPE on the Linux machine.
In SymantecProtectionEngineAbortLog.txt file shows the following error
2023/08/04-11:51:11 300 XML files did not validate : Error Validating configuration.xml. Element '/configuration/Resources/System/JavaLocation/@value' value: '/opt/binaries/jdk1.8.0_191/jre/bin/java/java' is not a valid value of the local atomic type. Error Message: Configured java does not exist. Please configure the supported version of 64 bit java(1.8 family update 232 or later version in the same series).
Symantec Protection Engine 9.x
Linux Operating System
Java location path is incorrect/unreachable in the configuration.xml file.
1. Navigate to /opt/SYMCScan/bin directory.
2. Add the Java path by using the following command and start the SPE service.
- ./xmlmodifier -s //Resources/System/JavaLocation/@value /<Java file path> configuration.xml
Ex.
./xmlmodifier -s //Resources/System/JavaLocation/@value /opt/jdk1.8.0_301/bin/java configuration.xml
3. Start the SYMCscan service.
/etc/init.d/symcscan start
This has been seen in rare cases when using special characters such as $ within the password for the Java Key Store (JKS), which prevents the Java instance from being accessible and leads to the same log entries. Removing this special character allows the access without incident.
