Endevor 18.0 MOVE ELEMENT system abend 0C4 in LMOD C1GSEXTI
Article ID: 271671
Endevor Endevor Natural Integration Endevor - Enterprise Workbench Team Build Brightside Zowe
When running the Endevor program NDVRC1 there was a system abend 0C4 in LMOD C1GSEXTI, CSECT C1GSEXTI.
Job Log extracts below:
 10.55.34 JOB12065  IEF863I DSN = iprfx.iqual.ARCHIVE JOB1 RC = 04 RSN = 00000000 FROM SERVICE ENQ
 10.55.34 JOB12065 *IEF099I JOB JOB1 WAITING FOR DATA SETS
 10.55.37 JOB12065  IEF403I JOB1 - STARTED - TIME=10.55.37
 10.56.03 JOB12065  +CCSR010E C1SSESTA S0C4 at 000C607E LMOD C1GSEXTI CSECT C1GSEXTI +005DBE JOB1 N/A NDVRBAT
 10.56.03 JOB12065  +CCSR021I OWNER = CA Endevor SCM R18.0
 10.56.03 JOB12065  +CCSR022I MODULE = C1GSEXTI FMID = CSIQI00 RMID = RO94401
 10.56.03 JOB12065  +CCSR061I PSW: 00000000 00000000 078D0000 800C607E
 10.56.03 JOB12065  +CCSR062I ILC: 04 INTERRUPT CODE: 04
 10.56.03 JOB12065  +CCSR067I COMPLETION CODE S0C4 REASON CODE 00000004
 10.56.05 JOB12065  +IDI0002I Module C1GSEXTI, CSECT C1GSEXTI, offset X'5DBA': Abend S0C4-X'4' (Protection Exception)
 10.56.58 JOB12065  IEA995I SYMPTOM DUMP OUTPUT  930
    930             SYSTEM COMPLETION CODE=0C4  REASON CODE=00000004
1CA Endevor SCM Version 18.0.10           Copyright (C) 1986-2017 CA. All Rights Reserved.         01AUG23 10:55:56     PAGE     1
                                           E N D E V O R   E X E C U T I O N   R E P O R T
           10:55:56  C1G0202I  ACTION #1 / STMT #2
           10:55:56  C1G0203I     MOVE     ELEMENT ELEM1
           10:55:56  C1G0204I        FROM ENVIRONMENT: environ      SYSTEM: system      SUBSYSTEM: subsys     TYPE: EASYPLUS STAGE ID: 1
           10:55:56  C1G0232I        OPTIONS:  WITH HISTORY, DETAIL REPORT, SIGNIN
           10:55:56  C1G0232I                  CCID: ########
           10:55:56  C1G0232I                  COMMENT: comment
           10:55:56  C1G0208W  ELEMENT NOT FOUND FOR SYNTAX STATEMENT #2
           10:55:56  C1G0202I  ACTION #2 / STMT #3
           10:55:56  C1G0203I     MOVE     ELEMENT ELEM2
           10:55:56  C1G0232I        OPTIONS:  WITH HISTORY, SIGNIN
           10:55:57  C1G0265I  PROCESSOR GROUP MISN00 FOR THIS ELEMENT WAS OBTAINED FROM ENVIRONMENT MAP
           10:55:59  SMGR139I  ELEMENT FOUND AT LOCATION environ/system/subsys/EASYPLUS SELECTED FOR FETCH PROCESSING
           10:56:01  SMGR120I  ELEMENT VVLL 0101 FETCHED FOR PROCESSING AT STAGE DEV2
           10:56:02  SMGR136I  ELEMENT VVLL 0102 CHANGES INCLUDE 49 LINES INSERTED AND 49 LINES DELETED
           10:56:02  SMGR130I  ELEMENT VVLL 0102 CREATED AT LOCATION environ/system/subsys/EASYPLUS
           10:56:02  C1G0240I  BEGINNING COPY TO SOURCE OUTPUT LIBRARY
           10:56:02  C1X0012I  STEP CONWRITE INVOKING PROGRAM CONWRITE
           10:56:02  C1X0013I  PARM=EXPINCL(N)
           10:56:02  C1G0280I  ELEMENT AT LOCATION environ/system/subsys/EASYPLUS SELECTED FOR PROCESSING
           10:56:03  SMGR127I  ELEMENT VVLL 0102 WRITTEN TO:
           10:56:03  C1G0000I     DATA SET iprfx.EASYPLUS
           10:56:03  C1G0000I     MEMBER ELEM2
           10:56:03  C1X0010I  STEP CONWRITE PROGRAM CONWRITE COMPLETED, RC=0000
           10:56:03  C1G0241I  COPY TO SOURCE OUTPUT LIBRARY COMPLETED, HIGHEST STEP RC WAS 0000
           10:56:03  C1G0265I  PROCESSOR GROUP MISN00 FOR THIS ELEMENT WAS OBTAINED FROM PRIMARY ELEMENT RECORD
           10:56:03  C1G0242I  BEGINNING DELETE FROM SOURCE OUTPUT LIBRARY
           10:56:03  C1X0012I  STEP DELETE INVOKING PROGRAM CONDELE
           10:56:03  C1G0112I  MEMBER DELETED FROM DATA SET
           10:56:03  C1G0000I     MBR/FILE ELEM2
           10:56:03  C1X0010I  STEP DELETE PROGRAM CONDELE COMPLETED, RC=0000
           10:56:03  C1G0243I  DELETE FROM SOURCE OUTPUT LIBRARY COMPLETED, HIGHEST STEP RC WAS 0000
           10:56:03  SMGR112I  ELEMENT VVLL 0102 DELETED FROM LOCATION environ/system/subsys/EASYPLUS
           10:57:00  C1G0140S  ENDEVOR - BC1PACTN ABENDED CODE=S0C4
           10:57:11  C1G0200I  ELEMENT ACTION REQUEST PROCESSING COMPLETED, HIGHEST ENDEVOR RC WAS 0016
           10:57:11  C1G0210S  SERIOUS ERROR HAS OCCURRED - PROCESSING WILL BE TERMINATED.
                     END OF EXECUTION LOG - HIGHEST ENDEVOR RC = 0016
Release: 18.0.10
An older 18.0.10 release is being used.  That issue was addressed when fixing an incorrect message ACMB02*I in batch in 2017 PTF RO97485. Therefore the advice is to apply that PTF.
Due to the End of Service Announcement for Endevor 18.0 date of February 29, 2024, it would also be advisable to start planning an upgrade to 19.0.
