When creating from templete and filling out the fields, the error is displayed:
API-1019: Could not process the request due to internal error.
The APP log shows:
ERROR 2023-08-07 07:09:45,373 [http-nio-8080-exec-1982] ppm.rest (user:session:PPM_REST_API) Exception processing request for resource [investmentTemplateCopier], query string [/private/investmentTemplateCopier]
java.lang.NullPointerException
at com.ca.platform.osf.object.rest.rule.ApiRuleHelper.processPreRules(ApiRuleHelper.java:313)
at com.ca.platform.osf.object.rest.rule.ApiRuleHelper.executePreProcessRules(ApiRuleHelper.java:121)
at com.ca.clarity.projmgr.template.AbstractInvestmentTemplateCopier.validateRuleBasedRequiredAttributes(AbstractInvestmentTemplateCopier.java:187)
at com.ca.clarity.projmgr.template.AbstractInvestmentTemplateCopier.validate(AbstractInvestmentTemplateCopier.java:152)
at com.ca.clarity.projmgr.template.AbstractInvestmentTemplateCopier.create(AbstractInvestmentTemplateCopier.java:128)
at com.ca.clarity.projmgr.rest.function.InvestmentTemplateCopierResource.create(InvestmentTemplateCopierResource.java:73)
at com.ca.ppm.rest.provider.FunctionResourceProvider.createResource(FunctionResourceProvider.java:168)
at com.ca.ppm.rest.provider.FunctionResourceProvider.createEntity(FunctionResourceProvider.java:140)
at com.ca.ppm.rest.resource.BaseResourceHandler.createResource(BaseResourceHandler.java:455)
at com.ca.ppm.rest.resource.BaseResourceHandler.createResource(BaseResourceHandler.java:289)
at com.ca.ppm.rest.resource.ResourceHandler.postResource(ResourceHandler.java:255)
at jdk.internal.reflect.GeneratedMethodAccessor550.invoke(Unknown Source)
Release : 16.1.2
Check the associated blueprint set on the project template.
Go to the blueprint Rules page and check for any incomplete rule.
Either finish or delete the rule.
Publish the blueprint.
