How to monitor Oracle OEM using UIIM
Article ID: 270921
Updated On: 11-29-2023
We are using a version of AS400 that is not supported by the Oracle probe. How do we monitor Oracle with UIM?
Release : 20.4
unsupported OS.
OEM has the ability to use snmp. As a work around, you can use snmptd or snmpcollector to monitor OEM.
