Repeated attempt to install SPE 9.0.1 to Linux (in this case Rocky Linux 8) failed because it could not find the path to where the Java binary file is located despite the fact that a supported version of Java was installed correctly.
Error: The required Java Runtime Environment could not be found. Please specify the base path where 64 bit Java is installed, 1.8 family updated 232 or higher in the series.
Release : 9.0.1, 9.1x
The installation program was unable to resolve the symbolic links to the actual path where the Java binary file was located. This is likely caused by how the Linux OS was configured when installed.
When Java is installed correctly you can run two commands to see where it is located and which path it would choose if invoked.
whereis java
which java
In the previous example the direct path to enter would be: /usr/java/jre1.8.0_361-amd64 (this points to where the /bin folder is which is where the java binary file is going to be)
