N01101 NetMaster ABEND S-212 : Problem loading the DSNREXX load module
Article ID: 268711
Updated On: 10-10-2023
NetMaster Network Automation SOLVE SOLVE: Access Session Management SOLVE:Access Session Management Solve:CPT SOLVE:FTS SOLVE:FTS SOLVE:Operations Automation NetMaster File Transfer Management NetMaster Network Management for SNA NetMaster Network Management for TCP/IP Unicenter NetMaster Network Management for SNA
SOLVE/NetMaster region receives ABEND S-212 when starting the SOLVE/NetMaster region.
Example of error in log:
N01101 NetMaster ABEND S-212 ID=SOLVE JN=SOLVE DT=2023169 TM=10295721
N01102 SRC=SE PRD=NetMaster INTLVL=080101 SP=01 ABC=S-212
N01103 ALM=NM001 ALO=000489C2 ACS=NM000062 ACO=00000842
Release : 12.2
This is a problem loading the DSNREXX load module. It is a REXX API to DB2.
Unfortunately there's no way to disable that specific REXX feature within NetMaster. Just as we do for NCL and OML, REXX is a supported part(language) of the base product of which during the REXX INIT process it attempts to load various modules for its support.
We have created PTF LU10544 which removes the loading of that DB2 REXX API. Loading of DSNREXX was introduced long ago with the thought that perhaps a customer might use it.
