Classic PPM navigation problem while using Firefox
Article ID: 268268
Clarity PPM On Premise Clarity PPM SaaS Clarity FedRAMP
When hovering over the home button in Classic view, when you go and the right mouse clicks on an item to choose it to be opened in a new tab, the home page view disappears. This only happens in Firefox
All versions of FIREFOX:
Tested: 112.0.2 (64-bit)
Steps to Reproduce:
  • Log in to Classic PPM as any user (tested using admin) using the Firefox browser.
  • Go to Home -->right click --> try opening any tile using the new tab.
  • The Home Context menu goes away from the page.
Expected Results: The context menu should not go away when any user tries to right-click and open the context menu in a new tab
Actual Results: The Context menu disappears when any user tries to right-click and open the context menu in a new tab
Release: 16.1.1
DE70039
Engineering fixed DE70039, and the fix will be available on the 16.1.3  release
