For Web Viewer 14.0, the client needs a fix for ++HOLD REASONS AS07570 and AL05268.
Release : 14.0
For AS07570 (in ++HOLD REASON, in PTF SO07570) and AL05268 (in ++HOLD REASON, in PTF LU05268), the client needs Web Viewer 14.0 PTF LU07837:
LU07837 -- Security or Integrity Problem
***NOTE*** This PTF corrects PE PTF SO07570
***NOTE*** This PTF corrects PE PTF LU05268
PROBLEM DESCRIPTION:
Security or Integrity Problem.
For more details access Security Advisories using the following URL:
support.broadcom.com/security-advisory/security-advisories-list.html
Broadcom recommends that you subscribe to notifications for Security
Advisories for the associated products that you support in your
organization. Please use the following URL to register for proactive
notifications: https://support.broadcom.com/user/notifications.html
SYMPTOMS:
N/A
IMPACT:
CIRCUMVENTION:
N/A
PRODUCT(S) AFFECTED:
Output Management Web Viewer Version 14.0 .
To download LU07838:
. Go to the Broadcom Support Site.
. Go to "Products"
. Search by Product Name ... VIEW
. Click on "Product Details"
. Click on "Downloads"
. Click on "Solutions"
. Click on the right-pointing arrow on "View MVS"
. Click on release "14.0"
. In the Search box, put in LU07837 and press [Enter]
. For LU07837, click on the cloud to download
