OPS3000S ESTAE LEVEL 1 SYSTEM ABEND CODE=422 TIME=07:08:07 SEQ=0 CPU=00 ASID=0092 (0011 0011)
Article ID: 267396
OPS/MVS Event Management & Automation WatchTower WatchTower Platform
Received the following messages during system shutdown:
OPS3006I PSW AT TIME OF ERROR 070C1401 80FF1126 ILC 2 INTC 8A RSCD 74BA04FF
OPS3007I CURRENT ROUTINE NAME=OPSQFU ADDRESS=0810B5A0 OFFSET=UNKNOWN
OPS3008I GPR  0-3  40000001 D2AE51E0 00001960 00000000
OPS3008I GPR  4-7  81145CD6 86399800 00F51400 03157000
OPS3008I GPR  8-11 00000000 01146B10 00000000 00000000
OPS3008I GPR 12-15 03407000 02DDE798 81145CD6 00000000
OPS3008I AR  0-3  00000000 00000000 00000002 00000000
OPS3008I AR  4-7  0101006D 00000000 00000002 0101006D
OPS3008I AR  8-11 00000002 00000000 00000002 00000002
OPS3008I AR 12-15 00000000 00000000 00000002 00000000
OPS3009I ABENDING LOCATION  OPSQFU+UNKNOWN
OPS3009I UNKNOWN  CALLED BY OPSQFU+X'BC8'
OPS3009I OPSQFU   CALLED BY OPRXSQ+X'CB2'
OPS3009I OPRXSQ   CALLED BY OPRXCMRU+X'7AA4'
OPS3009I UNKNOWN  CALLED BY SYSTEM+UNKNOWN
Release : 14.0
It seems OPS/MVS was a victim of an abend of another task. It seems this task abended because TCP/IP was stopped too soon in the shutdown process. See this message:
IEF450I xxxxxx xxxxxxx - ABEND=S422 U0000 REASON=74BA04FF
The '04' in the reason code above according to the IBM documentation is a TCP/IP reason code.
The solution is to include TCPIP as a pre-requisite for this resource
