UIM - using "SQL" filter criteria for creating groups in operator console
Article ID: 265603
You get the following error message when using SQL criteria for device filtering in the groups creation dialog window (operator console):
"Error |Invalid Sql Query . SELECT sub.cs_id AS id FROM (-OUR QUERY-) sub ".
Release : 20.4, 20.3
Operator Console
The SQL query that was used for filtering, does not return cs_id value.
The requirement for the SQL filter is that the SQL query MUST return the cs_id of the desired computer systems, so the application can correlate the cs_id with those computer systems/devices. Having this knowledge you can create various SQL queries with JOIN clauses which will allow for very wide and custom filtering criteria.
