It is sometimes useful to see the output of a listing in hexadecimal. It will allow the user to see the HEX value of an unprintable character. Is there a way to do this?
The DMX command will display the hexadecimal representation of the data identified by the last executed DISPLAY, INPUT or OUTPUT command.
To use the command, select the member you wish to view in the List queue and type in DMX on the command line.
