search
cancel
Search
ITCM console – Remote Control view
Article ID: 263756
Feedback
Subscribe
CA Client Automation - IT Client Manager
Show More
Show Less
n DSM Explorer the 3 following folders are missing under Remote Control
Active Sessions
Previous Sessions
Rejected Sessions
Client Automation 14.5 CU5
Open a case at CA Broadcom technical Support and ask for fix
T437401
This fix should be applied on computers with DSM Explorer 14.5 with CU5
Remark : This fix should be included in next CU patch.
Feedback
thumb_up
Yes
thumb_down
No
