When viewing the DLP Incidents by Individual Normality Rating dashboard in the Information Centric Analytics (ICA) console under Data Loss Prevention > DLP Overview, event normality scores do not appear to be updated outside of the nightly processing job.
Release : 6.x
Component : RiskFabric Intraday Processing
Although entity risk scoring only takes place during the nightly RiskFabric Processing job, event normality scoring is performed by both the nightly and intraday jobs. Possible reasons event normality scoring might not be updated intraday include:
To enable the RiskFabric Intraday Processing job, follow this procedure:
The following queries can be used to investigate potential failures in event normality scoring:
SELECT DISTINCT en.RFCreatedDate AS "ScoringDate",
di.RFCreatedDate AS "StagingDate"
FROM RiskFabric.dbo.LDW_EventNormality AS en WITH (NOLOCK)
JOIN RiskFabric.dbo.LDW_DIMIncidents AS di WITH (NOLOCK)
ON en.EventID = di.DIMIncidentID
WHERE CAST(en.RFCreatedDate AS date) >= CAST(GETDATE()-7 AS date)
ORDER BY en.RFCreatedDate DESC;SELECT *
FROM RiskFabric.dbo.Log_DataTransformation WITH (NOLOCK)
WHERE StatusFlag = 'F'
AND CAST(StartDate AS date) >= CAST(GETDATE()-7 AS date)
AND (
DestinationTableName = 'dbo.LDW_EventNormality' OR
StoredProcedureName = 'spNormality_UpdateNormalityScores'
ORDER BY 1 DESC;SELECT j.[name] AS "Job",
s.step_id AS "StepID",
s.step_name AS "StepName",
h.[message] AS "Message",
msdb.dbo.agent_datetime(run_date, run_time) AS "RunDateTime",
((h.run_duration/10000*3600 + (h.run_duration/100)%100*60 + h.run_duration%100 + 31 ) / 60) AS "Minutes"
FROM msdb.dbo.sysjobs AS j
INNER JOIN msdb.dbo.sysjobsteps AS s
ON j.job_id = s.job_id
INNER JOIN msdb.dbo.sysjobhistory AS h WITH (NOLOCK)
ON s.job_id = h.job_id
AND s.step_id = h.step_id
AND h.step_id <> 0
WHERE j.[name] = 'RiskFabric Intraday Processing'
AND s.step_id = 10
AND msdb.dbo.agent_datetime(run_date, run_time) >= CAST(GETDATE()-7 AS date)
ORDER BY h.instance_id DESC;
