OpenJ9 JVM support for Automation Engine and Oracle OEBS agent on AIX
Article ID: 262423
CA Automic One Automation
Which Open JVM version is cetified for Automation Engine and OEBS agent? Our client is looking for IBM Semeru Runtime Certified Edition 11.0.12.0 (build 11.0.12+7) OpenJ9 JVM support for AE and Oracle OEBS agent on AIX?
Release : 21.0.5
CA Automic Workload Automation
As confirmed with our engineering team, currently, there is no certification in place for JVMs. We recommend OpenJDK 11 and we rely on the OpenJDK compatibility. Please check our compatibility matrix below for supported Open JDK versions:
https://downloads.automic.com/tools/compatibility_matrix?compatibility-mode=component&offering_version_id=1570601284526&lifecycle_entity_id=1409143059253
