How to retain AAI system alerts for longer then 24 hours
Article ID: 262152
Automic Automation Intelligence
Release : 6.4.5
1. Launch the AAI Configuration tool
2. Go to the Parameters tab->Less commonly configured parameters
3. Update the alertExpirationInterval parameter and set to the desired time frame
4. Restart the AAI thick client
