External Connection to MSSQL is not working in 16.0.3 after the driver change
Article ID: 258760
Updated On: 10-26-2023
Clarity PPM On Premise
FATAL 2022-11-30 09:04:46,627 [Custom script execution pool-10-thread-9] union.persistence (clarity:XXXXXXX:none:none) Failed to initialize Context properties
com.microsoft.sqlserver.jdbc.SQLServerException: The driver could not establish a secure connection to SQL Server by using Secure Sockets Layer (SSL) encryption. Error: "PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target". ClientConnectionId:f9fb904c-fc1e-477c-96c4-01cb3228719c
 at com.microsoft.sqlserver.jdbc.SQLServerConnection.terminate(SQLServerConnection.java:3680)
 at com.microsoft.sqlserver.jdbc.TDSChannel.enableSSL(IOBuffer.java:2113)
 at com.microsoft.sqlserver.jdbc.SQLServerConnection.connectHelper(SQLServerConnection.java:3204)
 at com.microsoft.sqlserver.jdbc.SQLServerConnection.login(SQLServerConnection.java:2833)
 at com.microsoft.sqlserver.jdbc.SQLServerConnection.connectInternal(SQLServerConnection.java:2671)
 at com.microsoft.sqlserver.jdbc.SQLServerConnection.connect(SQLServerConnection.java:1640)
 at com.microsoft.sqlserver.jdbc.SQLServerDriver.connect(SQLServerDriver.java:936)
 at org.apache.tomcat.jdbc.pool.PooledConnection.connectUsingDriver(PooledConnection.java:347)
 at org.apache.tomcat.jdbc.pool.PooledConnection.connect(PooledConnection.java:228)
 at org.apache.tomcat.jdbc.pool.ConnectionPool.createConnection(ConnectionPool.java:764)
 at org.apache.tomcat.jdbc.pool.ConnectionPool.borrowConnection(ConnectionPool.java:692)
 at org.apache.tomcat.jdbc.pool.ConnectionPool.getConnection(ConnectionPool.java:198)
 at org.apache.tomcat.jdbc.pool.DataSourceProxy.getConnection(DataSourceProxy.java:134)
 at com.niku.union.persistence.connection.ApacheContext.getConnection(ApacheContext.java:243)
 at com.niku.union.persistence.connection.ApacheContext.getConnection(ApacheContext.java:207)
 at com.niku.union.persistence.connection.ConnectionContext.initializeContextProperties(ConnectionContext.java:738)
 at com.niku.union.persistence.connection.ConnectionContext.getContext(ConnectionContext.java:370)
 at com.niku.union.gel.tags.SetDataSourceTag.doTag(SetDataSourceTag.java:49)
 at org.apache.commons.jelly.impl.TagScript.run(TagScript.java:248)
 at org.apache.commons.jelly.impl.ScriptBlock.run(ScriptBlock.java:96)
 at org.apache.commons.jelly.TagSupport.invokeBody(TagSupport.java:187)
 at com.niku.union.gel.tags.ScriptTag.doTag(ScriptTag.java:20)
 at com.niku.union.gel.GELScript.run(GELScript.java:58)
 at com.niku.union.gel.GELController.invoke(GELController.java:79)
 at com.niku.bpm.services.ExecuteCustomAction.run(ExecuteCustomAction.java:217)
 at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
 at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
 at java.base/java.lang.Thread.run(Thread.java:834)
Caused by: javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
 at java.base/sun.security.ssl.Alert.createSSLException(Alert.java:128)
 at java.base/sun.security.ssl.TransportContext.fatal(TransportContext.java:321)
 at java.base/sun.security.ssl.TransportContext.fatal(TransportContext.java:264)
 at java.base/sun.security.ssl.TransportContext.fatal(TransportContext.java:259)
 at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(CertificateMessage.java:642)
 at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(CertificateMessage.java:461)
 at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(CertificateMessage.java:361)
 at java.base/sun.security.ssl.SSLHandshake.consume(SSLHandshake.java:392)
 at java.base/sun.security.ssl.HandshakeContext.dispatch(HandshakeContext.java:444)
 at java.base/sun.security.ssl.HandshakeContext.dispatch(HandshakeContext.java:421)
 at java.base/sun.security.ssl.TransportContext.dispatch(TransportContext.java:178)
 at java.base/sun.security.ssl.SSLTransport.decode(SSLTransport.java:164)
 at java.base/sun.security.ssl.SSLSocketImpl.decode(SSLSocketImpl.java:1152)
 at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(SSLSocketImpl.java:1063)
 at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:402)
 at com.microsoft.sqlserver.jdbc.TDSChannel.enableSSL(IOBuffer.java:2021)
 ... 27 more
Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
 at java.base/sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:385)
 at java.base/sun.security.validator.PKIXValidator.engineValidate(PKIXValidator.java:290)
 at java.base/sun.security.validator.Validator.validate(Validator.java:264)
 at java.base/sun.security.ssl.X509TrustManagerImpl.validate(X509TrustManagerImpl.java:321)
 at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:237)
 at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:110)
 at com.microsoft.sqlserver.jdbc.TDSChannel$HostNameOverrideX509TrustManager.checkServerTrusted(IOBuffer.java:1702)
 at java.base/sun.security.ssl.AbstractTrustManagerWrapper.checkServerTrusted(SSLContextImpl.java:1509)
 at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(CertificateMessage.java:626)
 ... 38 more
Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
 at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(SunCertPathBuilder.java:141)
 at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(SunCertPathBuilder.java:126)
 at java.base/java.security.cert.CertPathBuilder.build(CertPathBuilder.java:297)
 at java.base/sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:380)
 ... 46 more
Release : 16.0.3
Append "encrypt=true;trustServerCertificate=true;" to the connection string to resolve the issue.
Reference :- https://learn.microsoft.com/en-us/sql/connect/jdbc/connecting-with-ssl-encryption?view=sql-server-ver16
