Searching for a text string in an IPC source file
Article ID: 25848
Updated On: 12-11-2023
Ideal IPC
This article explains how a particular text string can be found in an IPC source file.
z/OS
z/VSE
Ideal
IPC all versions
To scan the VLS source file either:
  1. Use VLSUTIL SCAN  Function .
  2. Use Source Transport utility (IDUTSTRN) to transport the entities to an external source file then scan the external source file with a scan utility.
  3. Use GET$DATE. This sample application will scan the VLS source library to find all the programs that use $DATE and $INTERNAL-DATE. This Ideal code can easily be modified to search for any value in the program source. The GET$DATE application is attached.
VLSUTIL SCAN function
Ideal Source Transport Utility (IDUTSTRN)
GET$DATE.TXT get_app
