Not working with Edge browser and OM Web Viewer 12.1
Article ID: 258468
Updated On: 09-12-2024
Output Management Web Viewer
I can login and view reports with Chrome, but the supported web browser Edge is not working.
  • Output Management Web Viewer 12.1
  • Microsoft Edge
Running in IE  mode
Web Viewer 12.1 does not support IE mode when using Microsoft Edge. Running Edge in IE mode can cause several problems with Web Viewer.
To verify if you are running Edge in IE mode:
  1. Go to Settings
  2. Click on Default browser
  3. Make sure that the default for "Allow sites to be reloaded in Internet Explorer mode (IE mode)" is set to "Don't allow" or "Default".
