Where can the system requirements for Ghost Solution Suite be found?
For instance, what are the RAM and disk requirements?
Can the Symantec_CMDB Database use Full Revovery Mode Instead of Simple?
Release: 3.3
The system requirements for Ghost Solution Suite are found in the following documentation:
