Web Path Monitoring a Site Using Okta Authentication Errors with: waitForElementPresent timed out after 30s
Article ID: 257897
Updated On: 10-24-2023
AppNeta
Using a Web Path to monitor a site using okta authentication. When checking for the presence of the username field a 'waitForElementPresent timed out after 30s' is generated even though the page appears to load
Release : SAAS
The Web Path Site being monitored uses okta authentication and the script was checking
   for  waitElementPresent  id=okta-signin-username (although, when manually checking
   the page it seems to show  id=idp-discovery-username)
replaced:
with:
        xpath=//*[contains(@id,"username")]
After this the Web Path completes successfully and is able to authenticate (full script not shown)
