Hi,
We realized that when we try to mask a project with seedlist in FDM but using the masking configuration files (ZIP) coming from the TDM portal it fails everytime with error message
"2022-12-21 10:27:49.212 main - Error preparing select statement for cross reference select
2022-12-21 10:27:49.212 main - Invalid column index "
When we look at the "options.txt" file we see this parameter "SEEDTABLEINDEXCOLUMN=RD_INDEX" and if we run the masking in FDM without this parameter, it works fine.
Regards
Release : 4.10
product defect.
FastDataMasker-4.10.80.0.zip fixed the issue.
