When performing a test on the profile of the monitored resource, an error is generated notifying that files belonging to the SAP connector are missing or perhaps that some defined path is not correct. We tried to download and use a more updated SAP connector for ABAP, in this case 30.21. After modifying the PATHs the problem persists. We tried to update the sap_basis probe to 2.09, the version it is currently on, but the problem persists.
The robot where the sap_basis probe is running is a linux (RHEL 7.4).
Release : 20.3
missing sap library
missing sap_jco library
The attached file will work for Windows or Linux.
Once extracted set the path in the probe raw configuration
