IBM Fault Analyzer abends after applying several Top Secret PTFs.
The error received is:
IDI0065W CICS Exit SVC KEY8 MVS_ATTACH failed. Return code=FD7BE8
After fallback to the older TSS ptf level the problem is not happening.
The PTFS applied are:
LU05554 - CPF RECOVERY RECORDS ARE NOT CLEANED UP FROM CPFFILE
LU06640 - INCORRECT RETURN CODE ON RACROUTE VERIFY WITH SERVAUTH
LU06987 - TSSCFBK PRODUCES UNKNOWN DATA ENCOUNTERED MSGS WITH LU06089
LU07029 - MFA USER GETTING SUSPENDED WITHOUT PASSWORD IN CICS
LU07164 - ATTACH PROGRAM SECURITY BYPASSED WITH BMC BATCH OPTIMIZER
LU07457 - CICS ADDRESS SPACE ABENDS DUE TO X'15'S OVERLAY WITH LU02328
LU07505 - AUDIT TASK FAILS TO RELEASE LOCK DURING ABEND RECOVERY
LU07536 - SUPPORT THE USE OF UNIX SYSTEM SERVICES BY THE MSCA
LU07548 - CICS U0997 ABEND DURING START UP
LU07737 - SECURITY OR INTEGRITY PROBLEM
Release : 16.0
LU07737 is in error
