Moved to the FDM latest version 4.10.71.0 from 4.9.0.0. however, our BAU scripts are getting failed with below error message
Error message:
2022-12-01 11:54:21.624 pool-4-thread-1 - java.lang.NullPointerException
at com.grid_tools.products.datamasker.resolver.ResolverFunction.resolveFunction(ResolverFunction.java:703)
at com.grid_tools.products.datamasker.resolver.ResolverFunction.resolveFunction(ResolverFunction.java:312)
at com.grid_tools.products.datamasker.resolver.ResolverFunction.resolveFunction(ResolverFunction.java:162)
at com.grid_tools.products.datamasker.SQLUpdate.batchPreparedMasking(SQLUpdate.java:4367)
at com.grid_tools.products.datamasker.SQLUpdate.run(SQLUpdate.java:5605)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
2022-12-01 11:54:21.624 pool-4-thread-1 - exit value = 1
Release : 4.10.54 and above
After major changed to the data validation in FDM 4.10.54, it is observed that FDM is not managing the in memory seed table properly. The first time it works but the second access doesn't and gives null pointer exception.
The fixed binaries are available at https://ftp.broadcom.com/user/downloads/pub/TDM/FDM/FastDataMasker-4.10.75.0.zip
Use below article to apply the patch build:
