We are running Dx NetOps PM 22.2.1 on Linux, Can you help me to get the Speed In and Speed In Override for the specified interface?
Release : 22.2
You can find the Speed In and Speed In Override for a specific interface by doing these steps:
1. On the PC/Portal web page, click on Inventory --> Items --> Interfaces
2. Click on the specific interface in question. In my example, I clicked on Fa0/0 link:
3. Click on the Edit button (on the right-hand side)
4. You can see the Speed In and the Speed In Override values:
Another way:
1. On the PC/Portal web page, click on Administration --> Monitored Items Management --> Monitored Devices
2. Select the device in question (under Monitored Devices). Then click on Polled Metric Families. Then click on the Interfaces line (not the link). Then click on the gear button in the Name column. And select the ID column.
3. Select the value in Speed In and click on the Edit button.
Another way:
1. Take note of the Interface ID. In the example below, the value is 7442.
2. Open this URL, based on the interface ID.
http://DA:8581/rest/ports/<interface_ID>
http://DA:8581/rest/ports/7442
3. You can see the Speed In and the Speed In Override values:
