The canonical name of the server has three IP has ore than 2 IP addresses and only one IP is active at any given time. The switch of the IP address can occur at any time and even when the agent is still running. Is it possible for the Automation Engine to dynamically get the IP address of server of the agent ?
Release : 21.0.3
It is not possible for the AE to dynamically get the IP address of the server of the agent. The IP address is sent during the startup of the agent. This could be a product enhancement and should be requested using the link below.
https://community.broadcom.com/communities/community-home/librarydocuments/viewdocument?DocumentKey=f66fabb3-f6ee-4910-84c8-e56091aa65ee
