"Fonts are not installed' when running the CCS console
Article ID: 254568
Control Compliance Suite Standards Server Control Compliance Suite
Control Compliance Suite (CCS)
When running the CCS Console for the first time, you will see the following warning:
'Fonts are not installed'
Release : CCS 12.5.x and CCS 12.6.x
When the CCS console is run the first time, it will need to install the correct fonts to work properly.
Click the 'Install Now' button to install the required fonts.
