Problem with long time-outs on freshly installed servers on RHEL 8 (obsolete hibernate namespace?)
Article ID: 253768
CA Application Performance Management (APM / Wily / Introscope)
I'm doing some test installations of 10.8 on RHEL 8 in preparation for migration from 10.7 SP3 to 10.8.
I have installed a MOM and two collectors in a test-environment. There are no metrics or agents involved at this time. The systems are completely empty.
The issue is that it takes a very long time for the collectors to connect to the MOM when I start them.
It also takes a long time for MOM to allow for connecting via workstation-gui.
There are no Errors in the log files but there are warnings related to hibernate. I have the same warn-message in the logs on the MOM-server.
[WARN] [main] [org.hibernate.orm.deprecation] HHH90000012: Recognized obsolete hibernate namespace http://hibernate.sourceforge.net/hibernate-configuration. Use names
pace http://www.hibernate.org/dtd/hibernate-configuration instead.  Support for obsolete DTD/XSD namespaces may be removed at any time.
It looks like it hangs for 10+ minutes and then proceeds.
I'm supplying em.log from one collector and mom. Don't mind the "Connection refused" at the end of the mom-logs. I shut the collectors down.
The issue is the gap in time that occurs in the following place in the mom-logs:
[INFO] [main] [org.hibernate.annotations.common.Version] HCANN000001: Hibernate Commons Annotations {5.1.2.Final}
[INFO] [main] [org.hibernate.dialect.Dialect] HHH000400: Using dialect: org.hibernate.dialect.PostgreSQL95Dialect
And here in the collector-log:
What is this hibernate-function? Can I supply some parameter to get around this time-out behavior?
Release : 10.8
Applied new jar fix.  This fixed the issue.
The release is tentatively planned for December/January time frame.  Please note that this is not firm and that the time frame is subject to change.
