Error:
C1A0010E ALLOCATION ERROR RC=1708-8017, DDNAME=WRITEHFS
C1A0011E IKJ56228I PATH /my/path/name NOT IN CATALOG OR CATALOG CAN NOT BE ACCESSED
Failed to access the path but the path does exist what can it be?
Release : all
The error can be caused by the path not existing. The path must be exactly the same with upper/lower case. If it does exist check the permissions. The userid used by the Endevor process must have the correct access.
