Process Automation does not start with Assistive Technology not found error
Article ID: 252692
CA Service Desk Manager
PAM does not start. The following errors are recorded in c2o.log
2022-10-11 16:20:57,928 ERROR [com.optinuity.c2o.c2oserver.ServerManager] [ Initialization] Initialization of Server Manager Failed, will retry booting up -
java.awt.AWTError: Assistive Technology not found: microsoft.flows.rpa.desktop.uiautomation.JavaBridge
 at java.awt.Toolkit.loadAssistiveTechnologies(Toolkit.java:807)
 at java.awt.Toolkit.getDefaultToolkit(Toolkit.java:886)
Product: Process Automation Base
Release : 4.3
Edit the accessibilities.properties file under the PAM jdk folder\jre\lib comment out the assistive_technologies parameter using a # like
#assistive_technologies=...
save the change and start PAM
