Unable to print while using Edge and Chrome
Article ID: 252069
Updated On: 11-11-2022
Data Loss Prevention Endpoint Prevent
On some websites while using Edge or Chrome print functions do not work. When clicking print no dialog comes up.
This issue occurs if the DLP Symantec extension is loaded.
Release : 15.x / 16.x
Conflict with new google extension API calls.
This issue has been resolved in the most recent version of the Chrome / Edge extensions (16.0.100). The extensions should update automatically if the machine has access to the play store.
Workaround:
Stop monitoring the http / https channel
