Sample JCLCheck batch job for problem diagnostic
Article ID: 25077
JCLCheck Workload Automation
To help speed up problem diagnostic, Broadcom Support may request that the JCLCheck errors be reproduced using JCLCheck in batch mode
(EXEC PGM=JCLCHECK).  This Knowledge Document provides a sample JCL to execute JCLCheck in batch mode.
Release: All
Component: JCLCheck Workload Automation
The following sample JCL executes proc CAZ1JCHK from the JCLCheck CAZ2PROC data set:
//Z1EXJCHK JOB ...
//Z1EXJCHK  EXEC CAZ1JCHK, OPTION='O(OPTS)
//STEPLIB  DD  DISP=SHR,DSN=CAI.JCLCHECK.CAZ2LOAD                 <== change
//SYSIN      DD  DISP=SHR,DSN=YOUR.JCLLIB(JOBX)                            <== change
//OPTS       DD  *
AU JOB FULL LIST XREF SXREF PXREF NOSPIE CAISUPT(3,37)
OR
//STEP1     EXEC  PGM=JCLCHECK,PARM='O(OPTS)',REGION=0M
//SYSPRINT  DD  SYSOUT=*
//SYSTERM   DD  SYSOUT=*
//SYSABOUT  DD  SYSOUT=*
//SYSOUT    DD  SYSOUT=*
//SYSTSPRT  DD  SYSOUT=*
//SYSIN     DD  DISP=SHR,DSN=YOUR.JCL.LIB   <== Library where "JOBNAME" resides
//OPTS      DD  *
AU LIST FULL JOB XREF RUNT PDS CCLIST(99) INCLUDE(JOBNAME) NOSPIE CAISUPT(3,37)
Notes:
  • Remove option AU if you are not using AUTOPROC.  //SYSPROC DD must be defined instead.
  • Runtime option DEBUG(nnn) may be added to force a SVCDUMP when a JCLCheck error message is issued.  (nnn is the last 3 digits of the JCLCheck error message number.)  When this option is used, the dump is written to the system dump data with titled " DUMP TITLE=JCLCHECKDEBUGnnn".
When a dump is needed to diagnose an abend condition, add the following SYSMDUMP DD to the JCLCheck job:
//SYSMDUMP DD DISP=(MOD,CATLG),DSN=HLQ.SYSMDUMP,     <== change
//                     UNIT=SYSDA,SPACE=(CYL,(100,50),RLSE),
//                     DCB=(RECFM=FBS,LRECL=4160,BLKSIZE=24960)
If Abend-Aid is enabled, disable it by adding the following DD statement:  //ABNLIGNR DD DUMMY
If IBM Fault Analyzer is enabled, disable it by adding the following DD:     //IDIOFF   DD DUMMY
If CA-OPT II & CA-SYMDUMP are enabled, disable by adding the following DD: //CAOESTOP DD DUMMY
