Characters for SSKEY when setting up passticket profile records in ACF2
Article ID: 250416
ACF2 - z/OS ACF2 ACF2 - MISC
What characters can be used for SSKEY in ptktdata ssignon profile records in ACF2?
SSKEY(key-value)
A 16-character hexadecimal representation of the 8-byte encryption key for this application.
This encryption key must match the encryption key that is defined on the workstation.
Pertains to legacy PassTickets only.
To protect encryption keys from disclosure when PTKTDATA records are listed, the SSKEY field value is displayed as "*SUPPRESSED*".
The following sample message displays when a PTKTDATA record is listed:
SSIGNON / TSOSYS2 LAST CHANGED BY ACFUSER ON 04/18/21-11:51 MULT-USE SSKEY(*SUPPRESSED*)
See PTKTDATA profile record in the ACF2 documentation for more information.
The 16 character hexadecimal representation of the 8-byte encryption key
does not need to be actual characters
e.g. it could be ABCDEFGH in EBCDIC
which converts to C1C2C3C4C5C6C7C8 in HEX
or it could be unrelated to any real characters
eg A1e77f0e00001234
