MUX - To Do's not translated on Project Tile
Article ID: 250206
Clarity PPM SaaS Clarity PPM On Premise
For a user configured for another language, the 'To Dos' value is not translated on a Project Tile. It shows correctly in the list of items on the left row
STEPS TO REPRODUCE:
1. Configure a Project Blueprint to include 'To Dos' as one of the first four tiles (so it shows on the Project Tiles).
2. Create/Modify a Resource to change the local language
3. Log in with the user, and go to the Project Tiles.
Expected Results:
It should show the localized text of 'To Dos', just like it displays in the icon on the left side.
Actual Results:
Hover over the 'To Dos' icon, it will say 'To Dos' instead of the localized text
Release : 16.0.2, 16.0.3
Component : Clarity MUX UI Usability
This is resolved in the upcoming 16.1.0. It was originally tracked as DE66615
