Top Secret and TSSSIM using Quotes
Article ID: 249206
Top Secret for z/OS
 TSSSIM indicates access is denied.
Why does is TSSSIM indicating access is denied, while allowed in Top Secret
Release : 16.0
Component : Top Secret for z/OS
With all Resources except DATASET, TSSSIM will test exactly what you give as
input. So if quotes are used around the resource name, TSSSIM will test
the quotes as part of the permit.
With $DSN in TSSSIM, the data set name should be enclosed in single quotes. If
the data set is not enclosed in single quotes, the userid is prefixed to the
data set which may not provide the desired simulation.
