Package problem for installation of "probe" on probe of downstream hub
Article ID: 248339
During the installation of a probe via IM to a downstream robot getting the following error:
Package problem for installation of <probe> on /domain/hub/robot
Release : 20.4
Component : UIM - DISTSRV
Probe to be copied into the archive of the downstream hub where the robot is located.
