Migrate Monitoring - Problem with Usage - Internal Server Error
Article ID: 247682
Updated On: 10-24-2023
AppNeta
Receiving below error when migrating monitoring from source(old) monitoring point to destination(new) monitoring point:
Flow Analysis is not enabled on destination monitoring point, will be listed under Inactive for last 24 hours
Enable Flow Analysis on Destination(new) monitoring point
To enable click 1. Usage > 2. Monitoring Points > 3. Filter Monitoring Point and click 4. Play button to start flow analysis.
Run migrate monitoring and it will finish past Usage step
