Summary
Fine-tuning of data_engine, discussion of DB Best Practices, improved data_engine throughput, performance optimization, and more.
hub
Changed and adjusted hub postroute_reply_timeout from default of 180 to 300.
This value is also in seconds, and determines how long the hub will wait for a reply from any queue/subscriber after sending messages. It controls how long the hub waits (in seconds) for a reply from the remote hub after sending a bulk of messages on a queue before deciding that it didn't go through and then resends the bulk.
data_engine
Check and improved data_engine throughput
Changed hub_bulk_size from the existing setting of 1000 to 1750.
Check the data_engine throughput before and after making the changes. Wait up to 20 minutes... after repeated inspection during the session, we saw that avg. throughput was increased by +20,000 messages from an avg of approx. 41k, up to 65k-ish.
Check thread_count setting
Set data_engine thread_count to 24. The value of 24 was found to be optimal in lab testing. Any higher value hit the law of diminishing returns. You can check the throughput of the QOS Messages via the data_engine GUI before and after changing the setting and waiting at least 15 ins to see if the number of messages processed per minute increases.
- data retention settings were being honored.
- Note that partitioning is supported when enabled via the Admin Console and for Microsoft SQL Server Enterprise editions not for Standard editions.
Set data_engine data_management_timeout to 65536
This raw configuration parameter controls the time limit for data management jobs, and it is recommended to set it to 65536 to ensure that maintenance tasks like indexing complete successfully without timing out. Default is 7200 (seconds or 2 hours). 65536 is roughly 18.2 hours. Maintenance jobs should not have to run over 18 hours.
Identify Large Tables
Checked large tables via large table query and the largest was 323M. There were approx. 50 tables over 10M. Tables from 50M to over 100M may adversely affect database queries, OC performance or data_engine maintenance jobs. DBAs can help with purging data from large tables if the tables have grown out of control and need to be decreased but if partitioning is enabled there is no need for deleting rows from the tables, partitions would be dropped.
The data_engine GUI Status Tab can be clicked to open up a view of the amount of raw QOS being saved for a specific QOS object in a given table, e.g., QOS_PROCESS_MEMORY.
Note that the data_engine settings can be overridden with a more conservative value to save data for a smaller number of days, especially if the monitoring interval is aggressive but necessary.
Overall health check for data_engine and DATA management/administration completed.
