MUX, Using ‘Save As’ directly after using ‘Save’ to save Project details in a view, the changes are lost
Article ID: 246260
Clarity PPM SaaS
SUMMARY: After saving a view in the MUX using the ‘Save’ button, if ‘Save As’ is used immediately after, the changes that were made to the view are lost.
STEPS TO REPRODUCE:
  1. Create a custom view on Projects in the MUX and save it.
  2. Select a project and then click Details
  3. In the Details pane, select Configure
  4. Add some columns to modify the details
  5. Click Done, and then next to the view Name click Save
  6. Click the view dropdown and click ‘Save As’
  7. Do not modify the view name, and click Save, and then Confirm
Expected Results: Changes made to the project Details are retained
Actual Results : Changes made to the details are lost and seem to revert to some default setting
Workaround: Refrain from doing a Save As immediately following a Save
Release : 16.0.2
Component : Clarity MUX UI Usability
defect ID: DE65995 - FIXED in version 16.1
