Using System Alias on a Multi-Branch mapping where each branch is using the same System Alias, trying to add an element and get the following error:
zowe ebg mapping add-element gc893492 SystemAliasWorkEnvOnly --name PROGX1 --type cob --endevor-system EOCF2 --endevor-subsystem FACCC
Command Error:
System 'EOCF2' not found
Get the same error using different System/Subsystem names:
zowe ebg mapping add-element gc893492 SystemAliasWorkEnvOnly --name PROGX1 --type cob --endevor-system EOCF0 --endevor-subsystem FACCC
Command Error:
System 'EOCF0' not found.
zowe ebg mapping add-element gc893492 SystemAliasWorkEnvOnly --name PROGX1 --type cob --endevor-system EOCF --endevor-subsystem FACCC
Command Error:
System 'EOCF' not found.
Release : 18.1
Component : BRIDGE FOR GIT 2.11.0
endevor-bridge-for-git-for-zowe-cli version: 2.5.0
"environment": "DEV",
"name": "EOCF1-DEV",
"readOnly": false,
"stageNumber": 1,
"workEnvironmentOnly": false,
"systems": [
"name": "EOCF1",
"alias": "EOCF",
"subsystems": [
"name": "FACCC",
"filter": {
"elements": [],
"types": []
"name": "FACKC",
"filter": {
"elements": [],
"types": []
