CAZIP16E RC=127 jar cannot execute
Article ID: 246009
Common Components and Services for z/OS
Running CAUNZIP you experience these messages:
CAZIP16E: Shell Command export PATH=/usr/java/J7.1_64/bin:$PATH;cd /u/SMPE2/;jar -tvf 25454024.zip failed with RC=127.
CAZIP16E:  jar: cannot execute
 The user does not have execution rights on the JAR module..
The USS Administrator needs to increase the permission of the user running the CAUNZIP UTILITY (UID or GID assigned),
OR
Check the permissions at the location of the JAR module, ensuring that it can be executed.
