Content Analysis AV engine and pattern update download is failing with error "Error: 14094415: SSL routines: ssl3_read_bytes: sslv3 alert"
Article ID: 245123
CAS-S400
This error indicates that the appliance-key has been expired on the Content Analysis appliance.
Confirm the existing appliance-key certificate validity on the appliance with enable mode command -
#show ssl keyring bluecoat-appliance
Renew the appliance-key certificate using below enable mode command -
#request-appliance-certificate
