Problem with Java based agents like SAP, SQL, RA or Analytics which do not use the CHANGE_LOGGING_DAYS setting.
The log is changed every day.
Release : 12.3.x, 21.x
Component : AUTOMATION ENGINE
Bug.
Update to a fix version listed below or a newer version if available.
Fix version:
Component(s): Automation Engine
Automation.Engine 21.0.4 - Planned Release First Half September 2022
