Error received after editing a Cobol program via the Endevor Explorer in vsCode and right clicking then selecting the Generate Cobol Flow option.
Control Flow version 1.0.1
Release : 3.0
Component : Cobol Control Flow
Cobol Control flow depends on Cobol Language Support (Cobol LS) vscode extension.
Prerequisites for Cobol LS:
Java version 8 or higher with the PATH variable correctly configured.
