Android devices running SEP Mobile versions 4.9.0 or 4.9.1 may experience higher than expected battery consumption.
This was determined to be an issue related to multiple detection timers running simultaneously.
This issue has been corrected in SEP Mobile version 4.9.2, which was released on May 31st, 2022 to the Google Play Store.
