EEP does not work after starting o_eep_auth_client returns -101
Article ID: 242154
CA Automic Dollar Universe
After stop/start of a node, the Jobs conditioned by a File Resource monitored by the EEP are not detected.
The universe.log contains the following kind of errors:
| 2021-12-13 11:15:54 |ERROR|X|EEP|pid=5627.2| o_sld_auth_client         | LServiceApp_DollarUPacketReceive2 in error: Timeout while receiving/waiting for
 packet from incoming connection from X.X.X.X on 0.0.0.0:16004. Error or timeout while receiving packet from X.X.X.X (rc=0 errno=131). (received b
uffer of size 0, iReceivedByteCount=0).  [-101]
| 2021-12-13 11:15:54 |ERROR|X|EEP|pid=5627.2| o_eep_srv_impl_api_callba | Error authenticating the client. o_eep_auth_client returns -101
A stop/start of the EEP did not help, the issue continues occuring.
Release : 6.10.21 and superior
Component : DOLLAR UNIVERSE
Defect:  EEP failed to authenticate supervisor due to a concurrency issue between supervisor's working threads.
Workaround:
Restart the node (unistop + unistart).
Solution:
Update to a fix version listed below or a newer version if available.
Fix version(s):
Component: Dollar Universe
Dollar Universe 6.10.101 - Available
