I need to configure reboot probe for rebooting server at a specified time.
Release : 20.4
Component : UIM - REBOOT
Time Specification
The Execution option is only available when using the timed type. Specify a range of time where the probe should be active for a timed execution. You can also specify a range of time for a daemon execution. The probe becomes inactive outside of the defined range. The format of the time specification that is used in the Range From, Range To, and Execution .
