How to set monitor location using ASM API call when creating a new ASM monitor
Article ID: 240440
Updated On: 04-04-2025
CA App Synthetic Monitor
We are creating monitors using automation through the ASM API calls, but we need to specify the locations to be used since our product can only be accessed in the US. How do we set the specific location using the ASM API calls?
Release : SAAS
Component : APP SYNTHETIC MONITOR ENVIRONMENTAL
The ASM DEV team proposed to use the new API (v3).
https://api.asm.saas.broadcom.com/v3/
In the new API (v3) you have to use location IDs instead. The locations can be retrieved by the GET /locations AP call:
You can try the following command.
curl -X GET "https://api.asm.saas.broadcom.com/v3/locations/public" -H  "accept: application/json" -H  "Authorization: Basic <token>"
You need to use your own Authorization string.
Here is how you can get the Authorization string for your account.
Go to https://api.asm.saas.broadcom.com/v3
1- Authorize
use your login and API password.
2- Execute:  Get api-token
once successful, it will have Authorization: Basic <string> in the responses.
copy the string in the Authorization: Basic in the above curl command.
Run the curl command.
