How to monitor power consumption of a physical server
Article ID: 238388
Kindly guide me to monitor the power consumption of a physical server in Data center.
Release : 20.3
Component : UIM - SNMPCOLLECTOR
Hardware monitoring options:-
As long as you can enable the SNMP agent on the servers you want to monitor you can use:
SNMP-based:
- snmpcollector (NIC, CPU cores, RAM, FAN, Power Supply, temperature, battery, array, reachability, availability, etc.)
- snmpget (Requires loading of MIBs/Dependent MIBs for the metrics you need to monitor)
